matz126
Jul 08, 2025Aspirant
NightHawk AX6 AX4300 (RAX45) QOS issue
Ive just logged into my router panel on the web and i went to enable QOS to set priority to certain devices. At first it was working well i was able to set priotity one at a time but then it stopped ...
CrimpOn
Jul 08, 2025Guru - Experienced User
It would be helpful to know more about:
- Which QoS feature is involved (dynamic - on page 86 of the user manual, or WiFi Multimedia Quality of Service - on page 89 of the user manual)
https://www.downloads.netgear.com/files/GDC/RAX45/RAX45_UM_EN.pdf - Is the goal to set QoS for specific devices or to applications which typically run on certain devices? From the user manual, it appears that these QoS features are defined by application, not by device.
matz126
The goal is to set QOS for specific devices. For example i want to set the highest priority to my PC and i would want to set low or normal priority to an amazon alexa.
