matz126
Jul 08, 2025Aspirant
NightHawk AX6 AX4300 (RAX45) QOS issue
Ive just logged into my router panel on the web and i went to enable QOS to set priority to certain devices. At first it was working well i was able to set priotity one at a time but then it stopped ...
CrimpOn
Jul 08, 2025Guru - Experienced User
Thanks for clarifying the objective. (makes sense to me)
Alas, it is not clear (to me) that the QoS options on this router are designed to do that. Not having an RAX45 myself, all I can do is read the User Manual. Nothing in the manual appears to refer to identifying a device to have higher QoS than other devices.
Perhaps you could post a screen capture of the page used to specify that a specific device is to have higher QoS than other devices?
