gaschadler's avatar
gaschadler
Follower
Dec 06, 2020
Nighthawk AX6
Nighthawk AX6 - AX5200 WiFi Router
Trying to set up ReadySHARE USB Printer Utility 3.1 for Mac. (Running most current version of MacOS)
Get error when trying to install. Did not complete install.
Appears download is incomplete. Tried multiple times. No joy.
2 questions:
      1) Does this router allow printing via ReadySHARE? (Was told it did)
      2) Is there an issue with the download? (Is there another link that can be used?)
This is the link that I am currently trying but keep getting errors:  https://www.netgear.com/support/product/ReadySHARE_USB_Printer.aspx#ReadySHARE%20Printer%20Utility%20Version%203.1%20(Mac%20-%20Supports%20MAC%20OS%2010.13%20and%20above)
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
