plwj
Feb 26, 2023Tutor
Nighthawk AX6600 not connecting to internet after extensive ISP outage
After our ISP (Home Telecom) had an extensive outage this week our AX6600 will not connect to the internet. The ISP has had many customers back online but not us; still down. Is there anything I ca...
Kitsap
Feb 26, 2023Master
plwj wrote:After our ISP (Home Telecom) had an extensive outage this week our AX6600 will not connect to the internet.
Is there anything I can try on my end to fix this issue or must I just wait on the ISP?
I was not able to find the AX6600 on the Nighthawk app. Is that because I am offline?
Thanks for your reply!
Need to know the model number of your router. The AX6600 is a speed label for marketing. Look on the label on the back of your device. Most likely begins with an R.....
What is the brand name and model number of the modem/gateway/ONT that is connected upstream of your router? Look on the label.
For configuration, do you have a device you can connect to your router with an Ethernet cable? The mobile applications are less than satisfactory for this task.
