plwj
Feb 26, 2023Tutor
Nighthawk AX6600 not connecting to internet after extensive ISP outage
After our ISP (Home Telecom) had an extensive outage this week our AX6600 will not connect to the internet. The ISP has had many customers back online but not us; still down. Is there anything I ca...
plwj
Mar 06, 2023Tutor
Thanks!
I’m back up now!
I’m back up now!
michaelkenward
Mar 06, 2023Guru - Experienced User
plwj wrote:
Thanks!
I’m back up now!
That's good.
If you can Accept as Solution the advice that worked for you, or explain what you did instead, that could help anyone who turns up later with the same problem.
While you are at it, save a backup copy of your current configuration for future use when you hit another problem.
