t-hayes's avatar
t-hayes
Nighthawk AX8 - RAX80-100NAS - IP lease time can't be set?
Since putting in the new router I've had several problems with connections being dropped for a few seconds and couldn't understand why.  It wasn't all at once and wasn't occurring that frequently.   My NAS which I have a nat passthrough for all the sudden failed, and when I looked the ip had changed.  My previous router would almost never change an ip address for a device, so I never had to hard set the ip. So I change the ip in the routing and the next day the ip had changed again, even though the machine had not rebooted or been off for any reason. I have since told the router not change it's ip, but for other devices this is becomming a noticable occurance.
I went looking to change the lease time, but there is no setting.  Also, why would you change the ip of a currently connected device that is using the internet?  Do I have to fix all my devices to not have their ip change?  I'm no where close to the 253 devices it can dish out for ip4, not even hitting 30, so I don't get why the ip has to change every day?  Since I've been using routers I've yet to have one, netgear or otherwise force an ip change daily.
So am I missing something or is there some secret way to have the router not do this?  for what I paid I expect less trouble from it than more.
  • michaelkenward's avatar
    michaelkenward
    Have you tried setting the IP address on the NAS device and reserving that address in the router?
    There is support for the RAX80, including a manual, at the end of this link:
    >>>RAX80 | Product | Support | NETGEAR<<<
    See the section Manage Reserved LAN IP Addresses.
  • I hard coded the IP address in my 2 NAS so as to not fight any of these problems. Be sure to pick an IP outside of the DHCP address scope. Never have had a failure since.
    • t-hayes's avatar
      t-hayes
      I decided to just send it back and buy something else.  For $400 I can't see having disconect issues all the time and the number of other little weird internet issues that have been more and more numerous.  For that kind money I expect things to work.
      • myersw's avatar
        myersw
        Master
        Things will probably work better if the replacement router does not have the name Netgear on it.
