KGT94's avatar
KGT94
Follower
Feb 28, 2019
Nighthawk AX8 DHCP Option 61 support
Hi. My ISP in the UK (SKY Fibre) requires DHCP Option 61 authentication support to log into the WAN via a VDSL modem. Sky doesn't support PPPoE or regular DHCP.
The R9000/X10 supports this as of v10.0.4.12. Before I buy an AX8/RAX80, does anyone know if it supports this, or can check? Thanks.
