drewbab1229
Feb 23, 2019Star
Nighthawk AX8 does not work with Sonos
Just some info for anyone considering purchasing this router. It does not work with Sonsos products hard wired to the ethernet ports. When I plug in either my Sonos Play 3 or a Sonos Boost to any o...
xjn
Apr 22, 2019Apprentice
Search Google for “Sonos broadcast storm” ... I have not seen issue with mine but I did read about it elsewhere. Try disabling the WiFi feature in the Sonos app to make sure they do not connect to Ethernet and WiFi at same time. I have a Beam, Sub, and two Play Ones with no issues. The WiFi is enabled on Beam so can connect to wireless Play Ones... the Play ones are connected to Beam but not router WiFi since connecting them to Beam wireless network already causes them to display as connected to the router.
