Theplum's avatar
Theplum
Nighthawk AX8 Internet Speed Test
Hi All,
    After an update to V1.0.1.62_1.0.26 on my AX8 router, it is impossible to update the network speed through SpeedTest (I can run the test but the result will return to the previous one after a page refresh). Is there a solution to this?
Tim
  • Hi All,
        I forget to mention that the SpeedTest is found under the QoS tab.
    Tim
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hello Theplum - We recommend performing a factory reset after a firmware update. Please perform a factory reset and let us know if you're running into the same issue.
      ~Christian
