Retired_Member's avatar
Retired_Member
May 02, 2021
Nighthawk AX8/8-Stream AX6200 Tri-Band WiFi6 Router not connecting to Xerox Workcentre 3225 Printer
I recently purchased Netgear Nighthawk AX8/8-Stream AX6200 Tri-Band WiFi6 Router. All the devices are connecting fine except my Xerox Workcentre 3225 printer.
Please note the printer is connecting to my older router without any issue.
I contacted Netgear technical support regarding this issue but they do not have resolution on it. The router is "Backwards compatible with 802.11a/b/g/n/ac wifi standards".
Netgear technical support asked me to disable "AX" and asked me to reset my router couple of times but nothing worked. Router firmware is aslo upto date.
Any solution and recommendation?
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello ap333,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
