mbrandon32
May 03, 2021Aspirant
Nighthawk MR60 - Satellite Won't Sync
Nighthawk MR60 satellite was connected for a couple weeks. All of a sudden, it was showing an amber light. So I disconnected and moved it closer to the router in order to re-sync. After multiple reboot and reset attempts, the satellite will not re-sync.
Any suggestions?
- Christian_RNETGEAR Employee Retired
Hello mbrandon32,
May you hold down the reset button for 15+ seconds using a pin/needle to factory reset the system.
Christian
- mbrandon32Aspirant
I ended up resetting both the router and satellite and starting over from scratch with both. Thank you for your reply.
Hello mbrandon32,
Thanks for providing an update to your post.
Christian
