pgjscottieuk
May 18, 2019Guide
Nighthawk Rax120 AX6000 plex port forwarding
After installing this router both ny netgear NAS 516 and 316 can no longer send alert messages
or update antivirus i configured this router with the same port forwarding as the old BT homehub 6 but...
schumaku
May 18, 2019Guru - Experienced User
Reads more like a different issue, unrelated to port forwarding. Have posted how to test the email notifications on ReadyNAS -> https://community.netgear.com/t5/New-ReadyNAS-Users-General/RN104-OS695-unable-to-send-alert-messages/m-p/1743238
- pgjscottieukMay 18, 2019GuideNAS messaging was all working fine before installing new RAX120 router swapped back old BT home hub all works problem is a setting in the router it is blocking outgoing from the NAS was also blocking Plex server on the NAS remote access
- microchip8May 18, 2019Master
is your NAT type set to "secure" or "open"?
I did look at that but when googled it said Open took down all your security leaving everything else computers etc vunerable so didnt try it is that the problem if its secure
