Sugrad90ae
Aug 13, 2020Aspirant
Nighthawk rax120 firmware
I'm trying to download a new firmware and it is suppose to have a .chk extension but every time I unzip a new firmware it shows as .img. What am I doing wrong?
It can be a .img or .chk file.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- Sugrad90aeAspirantThank you for the info. My real problem is that I can not access the routerlogin page of my router. I thought manually updating the firmware might help but everything I try has been unsuccessful. Somehow the router shows a non standard IP address starting with 174 and factory reset does not recover the normal 10.0.0.1. Any help is appreciated.
unhook it from your modem. If there's an ip address conflict, it can change the ip address during setup.
so factory reset it, leave it unhooked from the modem, and try and install it.
What modem do you have?
