Srl2007's avatar
Srl2007
Nighthawk RAX200 as APs across home
Brand new home built with Cat8 wiring to every level.  Can I put RAX200's on each floor and set them as APs and connect them with a netgear switch to create a wired mesh with the same SSID to cover the entire house?
3 kids and a ton of devices so the Orbi mesh networks keep getting bogged down.  Hoping the wired implementation will save us some backhaul bandwidth.
thank you!
  • plemans's avatar
    The only problem is its not a mesh system. You can use the same ssid but it won't roam like a mesh system would.
    You'd be better to look at the orbi AX system versus multiple RAX200's.
    • Srl2007's avatar
      Srl2007
      1 - thank you for the info
      2 - what will the difference be compared to the orbi mesh systems?
      my existing orbi system bogs down due to nest cams, Apple TV's, etc - just trying to takes advantage of the wiring
