ultravista
Oct 14, 2022Aspirant
Nighthawk RAX29 Router Constantly Dropping WIFI
My Nighthawk RAX29 constantly drops WIFI for some but not all devices. It may stop working for my laptop for example while the XBOX, Vonage, and Google Home and other devices still have internet.
On the laptop, the device is connected with 'no internet'. Disconnecting & reconnecting has no impact. Only reboot of the router works. Another laptop or computer is still connected and WIFI is fine. It is random and device independent.
When logging into the router from the affected device, all of the settings are active and the internet signal from the provider is strong. Only rebooting the router brings back WIFI to the device.
The previous firmware was V1.0.6.74_1 and I upgraded to V1.0.7.78_1 with zero change in WIFI dropping.
I have an older 2.4 GHZ Netgear router that never drops connection.
RAX29 is not a selectable product. Not sure why ...
Any suggestions?
what modem/gateway are you connected to?
Have you noticed if it tends to be 2.4ghz or 5ghz that the issue happens with?
Do wired devices drop?
- ultravistaAspirant
I've been reading through the forums and it appears my problem is not specific to the device but affecting a lot of other users with varied model numbers. Same exact problem, WIFI drops for some (but not all) devices and wire connections remain unaffected - rebooting the router solves for short period. Rinse and repeat.
Search "WIFI drop" in this forum and you'll see that the problem affects many users independent of the model #.
I am not sure how the devices are connecting 2.4 or 5 ghz. The router is still broadcasting and it shows "connected, no internet".
The RAX29 is connected to a Netgear modem and also an older Motorola surfboard modem. Regardless of which modem, WIFI drops while wired connections are unaffected.
Yes you will see "wifi drop" as an issue in the forums. Its a support forum where people come with issues. So you find issues here. That applies to any consumer networking forum. Search any of them for "wifi drops" and you'll find a bunch of posts. Its like going to a hospital and searching for sick people. Thats what you'll find. And then you'll think "well, everyone is sick". But its because of where you're at.
Did you try just a factory reset?
And what models are these modems?
