KBogo
Jul 19, 2022Tutor
Nighthawk RAX30
Never noticed this before, but my ethernet's name and the wifi's name are not the same. Should this be the case??
Jul 20, 2022Guru - Experienced User
Are you talking in windows?
if so then no. Windows names it when you first connect a device to it based on its own guidelines.
You can change it if you want in windows if it bothers you but it means changing the registry.
How to change network names on Windows 10 - gHacks Tech News
