Farscaper
Oct 25, 2022Aspirant
Nighthawk Rax35v2 Port forwarding
Hello, Weird issue with New router. Router has been updated to the latest firmware 1.0.11.112 before first use. So the issue is the router won't accept more than one port and more than one port ra...
michaelkenward
Oct 26, 2022Guru - Experienced User
Farscaper wrote:
So the issue is the router won't accept more than one port and more than one port range. For example I add Tcp 3074, 2000-21999 and I tick the "use the same port range for internal port" after I apply the settings it shows me only Tcp port 3074 listed as the applied port and the port range I added is not there. I've tried imputing the required ports I need in different variations but the end result is the same where only one port is shown.
Where are you doing this?
What is it that you are trying to set up?
- FarscaperOct 26, 2022AspirantI'm doing this under the port forwarding section. And I'm trying to forward ports for a video game.
- FURRYe38Oct 26, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Did you first disable uPnP on the router before configuring PF rules?
- FarscaperOct 26, 2022AspirantAX3000 Nighthawk AX4 4 stream Wifi 6 Router (RAX35v2)
Upnp has been disabled.
To reiterate the router is only accepting either one port or one port range not a mix of ports and port ranges together.
