Farscaper
Oct 25, 2022Aspirant
Nighthawk Rax35v2 Port forwarding
Hello, Weird issue with New router. Router has been updated to the latest firmware 1.0.11.112 before first use. So the issue is the router won't accept more than one port and more than one port ra...
Farscaper
Oct 26, 2022Aspirant
I'm doing this under the port forwarding section. And I'm trying to forward ports for a video game.
Oct 26, 2022Guru - Experienced User
Did you first disable uPnP on the router before configuring PF rules?
- FarscaperOct 26, 2022AspirantAX3000 Nighthawk AX4 4 stream Wifi 6 Router (RAX35v2)
Upnp has been disabled.
To reiterate the router is only accepting either one port or one port range not a mix of ports and port ranges together.- FURRYe38Oct 26, 2022Guru - Experienced User
Sounds like you'll have to input single port or a range separately then.
What app or device are you trying to set up PF rules for?
3074 is for xbox live and normally doesn't need any PF rules. uPnP handles this normally.
- FarscaperOct 26, 2022AspirantYea it looks like I have to input the ports and ranges separately, that port "3074" is also used for call of duty on the pc side which I'm suing. I'm not using an app I'm logging into the router from my PC. I feel like this is a bug because the instructions in the port forwarding tab say I can mix ports and ranges together.
