KC_CHOW
Sep 19, 2020Follower
NIGHTHAWK RAX40: How to set schedule blocking
I am using Nighthawk RAX40 (Firmware Version V1.0.3.80_1.0.1), and I would like to set the schedule to block the wifi connection.
After logging in, I have followed the instructions according to the manual i.e. 'Advanced' > 'Security' > 'Schedule'. After selecting the day, period and time zone, I then pressed 'Apply' but it doesn't work. The wifi connection is still on. However, if I try to set 'Access Control', it does work.
Does anyone knows why?
Thank you.
1 Reply
- Christian_RNETGEAR Employee Retired
Hi KC_CHOW,
Were you able to setup your schedule blocking? You may need to factory reset and run through the setup assistant again or power cycle the router.
Christian
