jacobw77
Mar 02, 2021Follower
Nighthawk RAX40 Wifi stops transmitting
I have a RAX40 that works great, but it seems like after approx 12 hours the WiFi signal just stops transmitting. After I reboot the router it works great again, and it's a constant struggle.
I've gone through the setting multiple times and cannot find a reason for why it does this.
1 Reply
Did you setup a schedule?
Sometimes a simple factory reset and reinstall removes a setting that could be causing it. have you tried that?
