Austin_007's avatar
Austin_007
Nighthawk RAX45 Turns off WiFi and internet connection LAN Ok
So ever since the last Firmware update in April, My RAX45 would turn off Internet connectivity and WiFi on its own sometime overnight.  I have to reboot the router and then everything is fine again.  So I started Tracking this in July, it happens Every 5 Days, like clockwork.  I tried changing the Netgear NTP server to a different one, but that didn't change the behavior.  So on Aug 7th after it shut down overnight again, I changed the Time Zone from -6 to -11  and Guess what, Now it does the shutdown in the morning @9:23am .  So the Router is definitely basing this behavior on the Time.   Question what hidden code have they put into the firmware that is causing this, and is it changeable?  If not can I roll back to the Previous Firmware which did not exhibit this behavior?  Help
Greg
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a factory reset and setup from scratch been performed since last update?
