tennell's avatar
tennell
NIghthawk RAX50 - Certifiate
I have been getting prompted to install a security certificate. The information on the certificate looks legit from netgear, but the certificate is NOT trusted. Is there some one from Netgear monitoring this community that can clarify if this is indeed a valid certificate from Netgear? I have included a screen shot with the details. Thank you.
  • plemans's avatar
    Photos have to be approved by a moderator.
    You can attach them by clicking on "choose file" while replying and we can see it right away.
    When are you getting the request?
    • tennell's avatar
      tennell
      I restarted both my computer and the router so I am not certain which event triggered the prompt for the installation of the certificate. My guess would be the computer.
      Screen shot attached again per your message. Thank you
      • plemans's avatar
        But what are you doing to get the prompt?
        trying to login to the router?
        Just browsing online?
        whats actaully causing it to pop up?
        do all devices get the prompt? only 1?
        and modem do you have?
