jayceross's avatar
jayceross
Nighthawk rax70 add mesh system
I'm wondering if it is possible to add a mesh system to my current router. the nighthawk RAX70.
Thanks,
  • plemans's avatar
    Add a mesh system to integrate with it? or to add to it?
    And are you talking adding a mesh extender like the EAX10/20/80 or are you wanting to add a mesh system like orbi?
    I've ran a mesh system in conjunction with my RAX router without issues.
    They don't integrate together but so long as you use a different ssid and keep them on different channels, they work together great.
    • jayceross's avatar
      jayceross
      Ya I was looking to add a nighthawk mk62- netgears mesh system and if it integrates nice
      • plemans's avatar
        No, the RAX and the MK series don't integrate.
        You can go:
        Modem---->RAX (in router mode)----->MK series (in access point mode)
        I've done this multiple times as I try out new things.
        Just use a different ssid for the MK series and have it on different wireless channels so there isn't interference
