RiaT
Mar 13, 2022Follower
Nighthawk RAX70 Compatible Modem
I have just purchased a NETGEAR Nighthawk Wifi 6 Router (RAX70) after reading multiple recommendation about it.
Unfortunately, I didn't realize I needed a separate modem for it.
What reasonable priced compatible modem can I purchase for it?
I am grateful for any advice.
1 Reply
What service do you pay for?
Who's your isp? those a kind of key questions.we usually recommend checking with your isp to ensure the device you're looking for is compatible.
