roninremy
Mar 01, 2022Guide
Nighthawk RAX70 Full Gigabit wired speeds but half Over Wifi
Hi Everyone,
I tried to do a search online but I am getting so many different answers of (yes you should get these speeds and no you shouldn't)
I just upgraded to gigabit net, and wired to my PC I am getting the full gigabit, but when I am trying to get the same speeds over wifi... it is about half or less.
I know you probably wouldn't hit the same speeds but I was expect more along the lines of 750-850 down/up, but I am getting more like 400 down/up or less depending on how far I walk away..
I am litterally in the same room with my router (for testing) and I get those speeds 400 speeds.
QoS is turned off.
Any insight would be awesome. Even if this is how it actually supposed to be. I figured with overreaching bandwidth headroom (yes I know this is in ideal conditions) I would get somewhere near those gigabit speeds but not half.
a lot of it is usually it isn't the router thats limiting the wireless speed but the device you're testing on.
What device are you testing with?
What link speed are you getting? (hint, actual throughput is roughly 55-65% of link speed)
How do I go about testing the link speed?
I am using a iphone 13 pro max / Macbook M1 - Tested on both similar speeds.
plemans wrote:a lot of it is usually it isn't the router thats limiting the wireless speed but the device you're testing on.
sorry! no clue on a mac. I'm an android/windows guy.
Anothter thing to check.
The RAX70 is a triband. The 5ghz is much much faster than the 2.4ghz.
But with that said, the 1-5ghz band is only a 2x2 antenna 1.2gig connection (80hz).
the other 5ghz is a 4x4 antenna (160hz) 4.8ghz band.
so try disabling smart connect and test each 5ghz band and see what you get.
(5ghz band will drop speed quickly with distance/obstructions).
