sachk's avatar
sachk
NIGHTHAWK RAX80 AX6000 Wifi 6 Router- 2.4GHz slow speeds
Firmware Version: V1.0.4.120_1.0.61
Router: NIGHTHAWK RAX80 AX6000 8 Stream Wifi 6
Hi All,
I am getting really slow speeds from my router. I have an internet connection providing 145 Mbps but, the 2.4Ghz mode from the Wifi router only ever outputs around 50 Mbps however, the 5Ghz mode works fine. The 2.4 Ghz mode used to work fine until we had our internet connection upgraded.
Any ideas what could be the cause of the slow speeds in the 2.4Ghz mode and how to solve this?
Thanks,
All
  • plemans's avatar
    2.4ghz is a slow network and sensitive to interference.
    have you tried changing which channel you're broadcasting on?
    What speeds were you gettin gover 2.4ghz?
    • sachk's avatar
      sachk
      Hi plemans
      Before the internet upgrade the speed was 50Mbps and we were getting the full 50Mbps over 2.4Ghz mode. Now the internet connection has been upgraded to 145Mbps I'm expecting approximately 145Mbps over 2.4Ghz mode. But unfortunelty we're getting speeds of around 40Mbps which makes me think something is wrong.
      I have tried changing the channels by using a Wifi Scanner app and the settings page for the router but still no joy. I have NOT tried a factory reset, do you think this is worth trying out? Would you have any other suggestions?
      Thanks
      • plemans's avatar
        Factory reset is worth a shot.
        I wouldn't expect 145mbps out of 2.4ghz. Its a slow network.
        If you're in an area with zero interferene and are close the router, 100mbps might be more realistic
