blamas1
Oct 08, 2020Aspirant
Nighthawk RAX80 dropping signal all day
I'm sure this isnt the first time this has been discussed but i have a specific question.
My router has been dropping the wifi signal (both bands) frequently for about a month.
I decided to call tech support today. I knew i was out of my initial techinal support window. I wanted to see if they would let me file a claim. Surprise that didnt happen, but they said I had too much signal interference.
They said if I renew my tech support ($150ish) They would do the following;
- Create a regional track ?
- Enlarge bandwith?
- Change my channel frequency?
I'm a novice here so what I'm asking first is will this fix my issue? Second, is it worth paying $150 for them to do this (ive spend so much on this router already)? Can I do this myself?
Any help would be much appreciated. Thank you
> Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Firmware version? Connected to what?
> for about a month.Do you mean that your wireless devices lose contact with the router,
or that the router loses contact with your ISP, or what, exactly? What
about wired devices?> [...] they said I had too much signal interference.
Not impossible. Far from certain. Especially if wired devices also
fail.> I decided to call tech support today. [...]
How, exactly, did you "call" whom, exactly? Hint: If you don't start
at/near "http://support.netgear.com/", then you might find yourself
dealing with some (other?) scam artist.> o Create a regional track ?
Huh?
> o Enlarge bandwith?
> o Change my channel frequency?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Specify Basic WiFi Settings". (Also "Troubleshoot".)
> [...] will this fix my issue? [...]Will minor parameter changes stop a recurring total failure? I doubt
it.> [...] is it worth paying $150 [...]
Not to me. $150 could buy a nice used router with a different name
on it. I'd expect that to be more educational.> [...] Can I do this myself?
Can you follow the material in the User Manual on the two items which
make sense? (And/or, do you know what "a regional track" is?)
