HelpWithThis
May 08, 2020Aspirant
Nighthawk RAX80 Ethernet Not Working
Hi,
I have a netgear nighthawk RAX80 and I have an audio reciever (a marantz SR6008) and its connected via ethernet to the router. However, it's not getting a connection. When I run the test I get an error that says "No internet connection check your routers settings" but I have no idea which settings it could be. It shows a diagram with the reciever connected to the router via ethernet which is marked with a green check, and then the router connected to the internet which has a red x. So my question for you is can you think of any settings that would be blocking this on the config page? The device has a MAC address and an IP address so I'm almost 100% it's not the device
FIRMWARE: V1.0.1.70_1.0.30
- plemansGuru - Experienced UserWhat modem are you connected to?
- HelpWithThisAspirant
It's an xfinity dual band wifi 802.11ac
