Koerisdagmail
May 27, 2024Follower
Nighthawk RAX80 Incorrect WIFI Password on certain devices
Have my Nighthawk RAX80 for a few years now, all updates done but on several devices I get the Incorrect WIFI Password. Even reading other discussions about the “no special characters” in the password I haven’t found a way to solve the issue. It only happens to certain devices (like iPad Air) and it is annoying as I am running several apps like Home Assistant which requires to be logged in the router (not the Guest WiFi option). Open to assistance.
If you're using icloud relay or private mac/ip address on the apple devices disable them.
Also, "forget" or remove the network from the apple device and try to connect
