Wiedeman's avatar
Dec 01, 2018
Nighthawk RAX80 not visible to Windows 10 laptop
I bought a Nighthawk AX6000 (RAX80) WiFi router.  All my devices (TiVo, Roku, iPad, iPhone, Android phone, Surface Tablet) connected without issue.  None of my ASUS Windows 10 Laptops with the Intel Dual Band Wireless-AC 7265 WiFi card could see the SSID being broadcast by the router.  Netgear tech support could not figure it out.  I exchanged it (thinking it could be one bad router) but the new one behaved exactly the same way.
Ultimately, I downloaded the Intel ProSet diagnostic application, which recommended and installed a new driver.  Then I could see the SSID (but still could not connect).  After some combination of rebooting the PC and rebooting the router, I am now on line (I had three laptops and had to go through this three times!)
I believe the driver updates Intel released in November 2018 are essential for PCs with this WiFi device to connect to this (and perhaps all late-issue) Netgear WiFi router.
  • dcboy3063's avatar
    dcboy3063
    Dec 24, 2018
    I too had this issue with my new RAX80 on one HP laptop with an intel chipset. My solution was to go to Intels site and download the recomended driver update. After update and reboot the laptop saw the RAX80's wifi ssid. I have over 30 devices connecting and that was the only one i had issue with.
  • michaelkenward's avatar
    michaelkenward
    Interesting. Seems that there was nothing wrong at the router end. This bit was the giveaway:
    Suggests that the Windows stuff was the source of the problem.
    Did these Windows PCs connect to other wifi sources? Before you applied the new drivers, that is.
    • Wiedeman's avatar
      Wiedeman
      Tutor
      That is a fair question, and one I glossed over.  These two-year-old ASUS laptops have been happily connecting to my older Netgear WiFi router ... I replaced it because it started dropping connections.  I was greatly surprised and puzzled at the difficulty with the new router.
        michaelkenward
        If you can bring yourself to do it, and the thing is still lying around, you could see if the new Windows drivers prevent the same dropouts on the old router.
        If so, that would point the finger firmly in Intel's direction.
      dcboy3063
      Initiate
      • TECHeSmurf's avatar
        TECHeSmurf
        I too had to use the Intel updater to fix this issue.  HP's driver did not work.
  • Disable “ax” functionality in WiFi settings, that should solve your issues. Plus without any ax clients that won’t cause any inconvenience.
  • I too had same problem..while using RAX80 and Lenovo laptop, intel wireless ac7260.
    I never had this kind of problem within 5yrs.
    I downloaded latest intel driver, and fix it.
    michaelkenward
    This is an important note for people. It deserves to be flagged up as a Solution. Unfortunately, you can't do that with a message that kicked off a conversation. So someone else has to get the credit.
    At least it will now show up in results when people bother to search this place for the problem.
