Andrew822
Oct 21, 2020Follower
Nighthawk rax80 Vodafone
Hi does this model require a modem to plug into? Or can it plug directly into the Fibre ONT on the wall? Thanks
1 Reply
- psychopomp123Luminary
It depends on what type of connection you have. If you have adsl2/vdsl2/FTTC, then the RAX80 will need to be plugged into a suitable modem. If you have FTTP, the it can be plugged into the Fibre ONT direct.
