p0se1d0nX
Mar 22, 2022Star
Nighthawk RAXE500 - POOR WiFi 5GHz Speeds (Need HELP Please)
Modem: Motorola 3.1 DOCSIS (latest version) Router: Netgear Nighthawk RAXE500 (latest firmware installed) ISP: Spectrum 1 Gig HSI -------------------------------------------------- Hello. I re...
p0se1d0nX
Mar 22, 2022Star
Hi plemans. Thanks for your prompt reply.
RAXE500 f/w: V1.0.9.78_2.0.38
Cable Modem: Motorola MB8611
Not sure about wireless card in laptop as I do not have it with me at the moment of typing this. I am using the latest iPhone (13 Pro) and latest iPad Air - but I figured I would be pulling better/faster download speeds than what I'm getting.
When running the internet speed test within the Nighthawk app (which gets the speeds directly from the modem) - I'm seeing 900+ mbps down. It's the WiFi speeds that seem underwhelming when running other speed test apps.
Should I leave OFDMA in 5GHz and MU-MIMO *enabled* or revert back to "default" with both being disabled?
Mar 22, 2022Guru - Experienced User
Hardwired will be faster than wireless because of network overhead on wireless devices.
I don't have an iphone to test with but I know they're a 2x2 antenna setup. Just not sure if they're 80/160hz wide support.
And most users are reporting around the speeds you're getting with iOS devices.
for example:
(there's more if you search)
The only time I've hit gig plus speeds on my raxe500 over wireless is when I'm connected with a AX210 card, at close range, and at 160hz wide channels. And even then, my starting point for my wired speeds is 1.4gig from my isp.
- Razor512Apr 13, 2022Prodigy
For the latest iPhones including the iPhone 13 (all models) that support 802.11ax, they are all capped at 80MHz channel width.
