Jose0131's avatar
Jose0131
Follower
Aug 16, 2022
Nighthawk router
It doesn’t want to do a update
  • michaelkenward's avatar
    michaelkenward
    That's a pity.
    What doesn't want to update whatever "it" is?
  • plemans's avatar
    What router do you have?
    What firmware are you on?
    What method of trying to update are you using? Through the app? Through the browser? Manually?
    What error does it give you?
    Where in the process is it failing?
    Details are key in helping
