pnfard
Mar 17, 2020Guide
Nighthawk RX40 5G issue (Version V1.0.3.64_1.0.1)
I have major issue with 5G,
1. It keeps disappearing in SSID list when \I am away from the router and then apepars.
2. When SSID is present and I am connected, I can see connected but no internet.
3. Sometimes when connected the speed drops 20 2 Mb/s with lots of latency for download. When I use other rotuers or my old virgin Router, I get minimum of 100 mb/s with the same distance away from router.
The only solutionis rebooting the router and that is annoying as some of devices connected to 5G stop working while I am away from home.
what modem are you connected to?
when you updated the firmware, have you tried a factory reset and re-install?
- pnfardGuide
Hi Pelmans;
I have virgin box set as modem mode and connected the netgear as main router and Wifi access.
1. I can confirm the latest version
2. I can confirm reset to factory default and re-confirm everything again.
Thanks
have you tried downgrading the firmware a version, factory resetting, and re-installing?
the RAX devices are the newest devices. maybe yours has a bug.
