Wbruce
Feb 26, 2020Aspirant
Nighthawk
Is it possible to connect A Nighthawk RAX40 to a Verizon Jetpack(Hotspot)? Thanks Bruce Techie just here says it can't be done.
michaelkenward
Feb 27, 2020Guru - Experienced User
The best people to ask for help are those who understand what the Verizon Jetpack (Hotspot) is and what it can do.
The RAX40 is sinmply a router. Forget the model number, look for advice on how to use the Verizon Jetpack with any router.
Perhaps this will help:
Search - NETGEAR Communities – Verizon Jetpack
- WbruceMar 02, 2020Aspirant
thank you
