bauerr7000
Feb 28, 2024Aspirant
nighthawkax5 ax4200 RAX42
cant login, says following:
Access Denied
Access to the requested page has been denied.
Have tried reset and reset password and still gives above message?
Thanks for any info?
If you updated FW, follow this to correct it:
- bauerr7000Aspirant
Am using this login http://192.168.1.1/start.htm
after enter the login port comes up and after entering login and password it redirects to following:
I have no idea what that is.
Does this mean the router went bad?
