Tes_Crys_Noice
Jan 16, 2022Aspirant
Nighthawk® AX4 4G LTE Modem + WiFi 6 Router SIM Compatibility
Hello! I have a question related to the Nighthawk AX4 4G LTE Modem WiFi 6 Router: https://www.netgear.com/home/mobile-wifi/routers/lax20/
It says in the SIM compatibility thing that has some certified mobile broadbands, as it comes: "Access 4G LTE on the cellular network as an alternative to wired internet. Now certified with AT&T, T-Mobile and Verizon. Select a data plan and activate a SIM card from your preferred provider1, or use the SIM card option included in box2. Not compatible with Sprint".
I haven't heard of those providers. My question is: will other mobile providers (like Vodafone, Orange, Digi or whatever that exist in Romania, the country where i live) be compatible with this router? From what have been written between the quotes, i understood that it is locked only in those providers and none others...
U can ask if u wanna understand more detailed. Please help.
- Tes_Crys_NoiceAspirant
This one from Amazon to be more exactly:https://www.amazon.com/NETGEAR-Nighthawk-4-Stream-Router-Built/dp/B08NXXJL1F/ref=sr_1_7?keywords=netgear+lte&qid=1642352135&sr=8-7
- DarrenMSr. NETGEAR Moderator
This is LTE router for North America. You can find a unlocked one here https://www.netgear.com/uk/home/mobile-wifi/routers/lax20/
- Tes_Crys_NoiceAspirantOk, this one will work with all cellular data peoviders from every country. Thanks for help.
