Curly9
Jul 08, 2019Aspirant
No 5ghz rax120
The 5ghz light is on but I can't connect to it or see it any ideas?
Curly9 wrote:
The 5ghz light is on but I can't connect to it or see it any ideas?Yes, you are trying to conect with a device that does n ot support 5 GHz.
But who knows? You don't provide enough information to diagnose things.
For example, what does "can't connect to it" mean?
- Curly9AspirantWell my phone S10+ connects to the 2.4ghz band. I've tried remaining the 5ghz to something else to see if that was why and got it to show up for a second then gone. I've tried on my computer which isn't ax capable bit it doesn't show up there either. In the setting it does have check box checked for broadcast ssid
What firmware are you running on it?
What wireless card does the computer have in it?
The RAX120 does have the option to use dfs channels but some devices can't use dfs/aren't compatible. Which channels on the 5ghz band are you broadcasting on?
Have you ever been able to see the 5ghz channels?
- aFireInside82Aspirant
If you have WiFi SmartConnect enabled, you may only see a single SSID for both the 2.4 and 5ghz networks.
The router's "connected devices" gui will show you which devices are connected via wired, 2.4, and 5ghz.
