Eyabsut1
Aug 18, 2020Aspirant
NO IP ADDRESS on my Nighthawk ax4 rax35
Need help my nighthawk AX4 AX3000 4 STREAM RAX 35 After a firmware update it Will not let any device connect to Wi-Fi or through ethernet cord Because there is no ip address It will not let me do the...
microchip8
Aug 19, 2020Master
Have you tried a factory reset? There's a reset hole/button at the back of the router. Push it in for 5-10 seconds while router is on
- Eyabsut1Aug 21, 2020Aspirant
yes I did, it did not work at all
