ckiori88
Mar 06, 2021Aspirant
Nokia 3 can not find Wifi SSID after upgrading the firmware 1.2.0.16 of RAX120
As title, I have a problem about that but it was work for the iphone series.
I can sure my Nokia-3's work well to find SSID and connect the wifi with old firmware version of RAX120.
Even the configruation was the same bewteen old and new version on RAX120 while Nokia-3 has the same os version.
Any idea or solution to solve the trouble?
- There seems to be a fault with dchp I dont know if Netgear are aware things you can do is 1st try on your phone making a static ip when connecting to wifi. 2nd pin hole reset or roll firmware back to .136 then reset again. Also forget the wifi ssid on your phone and try again
- thehypnootoadLuminaryThere seems to be a fault with dchp I dont know if Netgear are aware things you can do is 1st try on your phone making a static ip when connecting to wifi. 2nd pin hole reset or roll firmware back to .136 then reset again. Also forget the wifi ssid on your phone and try again
- ckiori88Aspirant
Thank you for the reply.
I just only roll firmware back to 1.2.0.136 and then my Nokia 3 work well to find the SSID of RAX120 as the same as the past.
I don't know what's the different firmware version but it was wrear thing after upgrade.
