Paulie1201's avatar
Sep 04, 2020
Performance issues with the CAX80
I purchased the CAX80 and I have had nothing but issues with it. The WiFi fails daily, and I am forced to reboot it. I never get my Gigabit speeds, even when I hardwired into the router. I am quick to blame Comcast, but all of the signs are pointing at Netgear. I never had these issues with my past Netgear routers; please fix these issues Netgear.
  • plemans's avatar
    Do you have a screen snip of the cable connections page? And the modem logs?
    Those help check the connection.
    If you have any splitters, amplifiers, attenuators in your coax line, remove them.
    Also try logging into the debut page: should be ip address/debug.htm    so 192.168.1.1/debug.htm  (or whatever you set for the ip address)
    make sure the "enable lan/wan packet capture" isn't checked.
    • Paulie1201's avatar
      Paulie1201
      Tutor
      Attached is the screenshot of my cable connection page.  Also, I tried the debug page and nothing happened.  I unchecked "enable lan/wan packet capture."
      • plemans's avatar
        your screen shot didn't tell us anything. You need the 32 channels downstream info, the upstream, and the ofdma channels and the logs.
