simonpollayil
Jul 11, 2020Tutor
Persistent connection issues with Apple HomePod
So I am having consistent issues with playing music through my HomePod via my phone (iPhone Xs) or my laptop (MacBook Pro), the issues crop up in two ways:
- I try to connect via airplay and it starts to play music, in a few minutes there's constant break up in the audio and makes it inaudible
- I try to cnnect via aurplay and my wifi network crashes, I have to restart my router to bring things back to normal
Does anyone have any experience with these issues? One splution I saw online eas turning off WMM but I didn't get a wifi 6 router to limit myself to 25mbps. Any and all recommendations are welcome :)
- Christian_RNETGEAR Employee Retired
Hi simonpollayil,
I would check to see if the router is due for a firmware update.
Christian .
- I actually solved the issue by rolling back the firmware to v1.0.2.60_1.0.1. This is unfortunate because I don’t have the latest security updates but it was between that or being able to use my devices
- hexixninAspirant
Rolling back?? :smileymad::smileymad:
I will try.
It seems that cannot upgrade the firmware casually :smileylol: :smileylol:
- thiefkidInitiate
My rax40 has the exact same issue. it doesnt help even if i roll the firmware back to V1.0.2.60_1.0.1. can you please help ?
- hexixninAspirant
yes
I had the same problem.
I used my iphone and share music via airplay.then,about less than 2 munites ,my wifi was crash. i need restart the route
my firmwar is v1.0.3.80_1.0.1
