rick0518
Jun 27, 2025Aspirant
Port Forwarding Intermittently Fails on RAXE500
After using the RAXE500 for a period of time, some of the port forwarding rules randomly stop working. If I edit and re-apply the affected rule, it starts working again. Has anyone experienced this i...
rick0518
Jul 01, 2025Aspirant
Be sure uPNP is disabled on the router. = yes already
netgear raxe500 v1.2.14
Thank you for your response. I’ve noticed that after my network updates its IP address (Internet, Dynamic IP), the port forwarding on the RAXE500 stops working. It only returns to normal after I re-edit and reapply the rules. Do you have any thoughts on why this might be happening?
- FURRYe38Jul 02, 2025Guru - Experienced User
How is the RAXE configured for internet connection? Using the Internet port or the Multi Gig port to the ISP modem/ONT?
Thank you for your response. I’ve noticed that after my network updates its IP address (Internet, Dynamic IP), the port forwarding on the RAXE500 stops working. It only returns to normal after I re-edit and reapply the rules. Do you have any thoughts on why this might be happening?- rick0518Oct 02, 2025Aspirant
What is the Mfr and model# : Askey RTF8207W-E / Internet port
When the dynamic IP changes, that DDNS is working fine, but port forwarding is not working
- FURRYe38Oct 03, 2025Guru - Experienced User
Which Dynamic IP changed? WAN or LAN for the device your PF config too?
Try setting a IP address reservation on the router for the devices your PFg too...
