SniperStorm
May 22, 2022Tutor
Port Forwarding rules disappearing!! 2022 Version!
Today I noticed that you could not access my telnet port from the outside. I looked at my port forwarding rules and they are all BLANK!( I will ad screen shots). If I goto try to add them again you get a screen that says "Port conflict with other service".
If I add a new port that I know is not set up it will let me do it.
Just a new note if anyone can help.
I already looked up this issues on the forums and it seem to be a constant issue with many routers leading to think its a software issue. I have seen many people complain about this but cannot find a solution.
It seems like the rules are there, but are hidden from view and not working.
Hi SniperStorm
What is the FW version you use ?
V1.0.10.82_2.0.39 Is my firmware version. It does not even matter. This issue seems to have been going on for years for many people on many netgear routers. I have to reload a saved config to be able to see the ports again,
- JenniferMathisAspirant
Is it solved?
- JamesMagillAspirant
Is it a solution? I've noticed that, too, but I'm not sure if the problem has been resolved.
