jmhga44
May 23, 2022Star
Problems with connection to work PC via gateway
I'm connecting from my home desktop to my office PC via a gateway and am having problems keeping the connection from dropping. I've talked to my Internet provider Spectrum and they do not see any problems in regards to the modem. When the connection to the office PC drops I am still able to browse web sites and see my home network without any problems. I also have just checked to see if there was a firmware update for my modem and there were no updates. Would anyone have any suggestions on this problem?
Thanks.
- microchip8Master
How about starting by telling us which router model you have and with firmware version (not "the latest" but a number). And how about telling us what modem or gateway you have in front of the router?
Router - Netgear RAX50
Modem - provided by Spectrum (EN2251)
Firmware Version - V1.0.11.112_2.0.77
- microchip8Master
Is the modem set in Bridge mode or router mode? If the latter, you're dealing with double NAT - https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
There should be only 1 router in your network. All others should be set in Access Point or bridge mode
