rfmodine's avatar
May 06, 2023
Problems with my RAX35
I have had to restart my router twice today to get wireless connections working.  It is up to date with firmware.  Not sure what the problem is.  I need help
  • rfmodine wrote:
    Once I restart the router, everything works again.  It is working well right now, but i don't have any idea how long that will last.  Any wireless device gets connection failed while this is going on however all of the lights on the router are solid green.
    A few quick and easy things to try.
    The simplest is to restart the whole network, not just the router.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
    If problems persist, then a rest of the router can help.
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front. It is also the first thing that Netgear support will recommend.
    You do have to reconfigure the router again. You can save a bit of hassle by saving the settings before you do the reset.
    How do I back up the router configuration settings on my Nighthawk router? | Answer | NETGEAR Support
    But be warned that restoring the settings may revive whatever caused problems in the first place.
  • 1. what modem/gateway is the router connected to?
    2. what actual firmware version are you on?
    3. What error do you get when you're needing to reboot? connected, no internet? is the wifi ssid not visible at all? What actually happens
    • rfmodine's avatar
      rfmodine
      Tutor
      Hardware Version
      R1.05
      Firmware Version
      V1.0.5.104_1.0.1
      GUI Language Version
      V1.0.5.104_1.0.0.17
      The modem is a netgear cm2050v.  I no longer have voice in use.
      The ssid IS visible
      When I try to connect, i get connection failed.
      Same thing happens with guest ssid
      While this is going on, my desktop, (physically cabled to the router), cannot connect to the router address, but I can see the internet from the desktop.  Once I restart the router, everything works again.  It is working well right now, but i don't have any idea how long that will last.  Any wireless device gets connection failed while this is going on however all of the lights on the router are solid green.
