Mr-Chris's avatar
Mr-Chris
R6700AX Firmware Update 1.0.19.172 Legit?
On May 20 my R6700AX reported a firmware update from 1.0.18.164 --> 1.0.19.172
but
https://www.netgear.com/support/product/r6700ax/#download
still reports 1.0.18.164
Just want to confirm that this is a legit firmware update...
  • NG sometimes will push new FW out to a limited amount of users. If all is good, then NG will post up on the download site.
  • FURRYe38's avatar
    • Mr-Chris's avatar
      Mr-Chris
      Thank You FURRYe38 - Okay, yes, firmware installed with no problem and all systems running normally...
      • FURRYe38's avatar
        Enjoy. 📡
