D_Day79
Sep 25, 2021Follower
R6700AX only getting 2 down and 1 up on 2.4Ghz
Purchased the R6700AX in March, have had nothing but problems with the speed on the 2.4Ghz band. Finally called support and had 2 phone calls of over 5 hours each troubleshooting the unit with no resolution. Consistently only get 2 mbps down and 1 mbps or less up on the 2.4Ghz band when I am directly in front of the router within 3 feet. Get about 230-240 mbps down and 12 mbps up consistently on the 5Ghz band.
When troubleshooting with support tried different channels to no effect and different firmware to no effect as well. I see all over the community support page that this is a very common problem with numerous different models of netgear routers. Switched from an Belkin router that never had this issue on the 2.4Ghz line. Upgraded to get more out of the speed I was paying for from Xfinity.
Has anyone found a resolution to this problem as of yet??
