Cgrower's avatar
Cgrower
Follower
Nov 18, 2023
r6700ax router blocks my iptv app from firestick max
how do i turn off security ?
  • schumaku's avatar
    schumaku
    Whatever IPTV App you talk of here, Several IPTV Apps like Roku for example, are location restricted. ROKU is often not available outside of the US.
    Further on, it can happen your ISP can block certain "services". You might have to use some VPN service allowing to set a virtual location to work around these restrictions.
    Unless you have subscribed some content management services like Netgear SPC or Circle, there is unlikely any other security blocking anything.
  • michaelkenward's avatar
    michaelkenward
    This is not a move that you should take willy nilly. It isn't even possible for some things.
    What for? And why? You have a problem that needs fixing?
    Your subject says something about a Firestick. Can you provide a bit more detail?
    What is this iptv app?
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Search for IPTV.
