brackishwaters's avatar
Jan 26, 2022
R7900 + WiZ Phillips Bulbs + Static IP Address Reservation = Not Possible?
Has anyone else ran into problems trying to assign their bulbs a static ip address?
Phillips WiZ bulbs, Netgear R7900
I have almost everything on my network assigned a static ip.  The only issue are these bulbs.
The message I get is:
400 Bad Request
This server does not support the operation requested by your client.
Anyone else run into this?
  • plemans's avatar
    How many assigned clients do you have?
    I remember reading somewhere there was a limit to address reservations/static addresses you can use. you can have more connected, just not with static addresses.
    • brackishwaters's avatar
      brackishwaters
      When I first encountered the problem, I had 2 static IPs assigned.
      Since then I have added 5 more.
      I have done the following troubleshooting:
      1. Light on and connected to wireless - 400 Error
      2. Light off, not listed as attached device in wireless, and manual assignment - 400 Error
      3. Light on - Full power to light (not dimmed), connected to wireless - 400 Error
      The only other thing that I can think of that may be contributing to the problem is that there is the 3rd part apps we use for these bulbs (WiZ and Google Home) when we initially setup the bulbs but there was no static ip address assignment declared during that process.
      • plemans's avatar
        They work fine if not set on a static IP?
        Why not leave them dynamic and then once they're working, reserve their IP address
